Philco B711
Hi folks,
I just got another Philco in my collection a model B711 from 1954.
The problem is it only picks up one station which is 620 KC. It will absolutely need a complete recap.
Philco B711 - by pete7189 - 10-03-2013, 09:53 PM
RE: Philco B711 - by Ron Ramirez - 10-08-2013, 07:39 AM
RE: Philco B711 - by pete7591 - 10-26-2013, 05:40 PM
RE: Philco B711 - by Radioroslyn - 10-26-2013, 08:26 PM
RE: Philco B711 - by pete7591 - 10-31-2013, 04:39 PM
Philco 91 Tuning Condenser
There are currently 8867 online users. [Complete List]
» 2 Member(s) | 8865 Guest(s)
