Shadowmeter Questions
Hi All;
PuhPow, I have never had a ShadowMeter, but maybe Your problem is not the Coil, but a weak Magnet.. I have watched a number of video's on ShadowMeters and just thought that it might be something for You to look at.. Google "Youtube ShadowMeter" and see what you get..
THANK YOU Marty
Shadowmeter Questions - by Jamie - 10-03-2013, 03:17 PM
RE: Shadowmeter Questions - by Jamie - 10-03-2013, 08:27 PM
RE: Shadowmeter Questions - by KCMike - 10-03-2013, 08:49 PM
RE: Shadowmeter Questions - by Jamie - 10-03-2013, 08:59 PM
RE: Shadowmeter Questions - by Chuck Schwark - 10-03-2013, 09:46 PM
RE: Shadowmeter Questions - by Jamie - 10-04-2013, 10:03 AM
RE: Shadowmeter Questions - by marty - 10-04-2013, 10:18 AM
RE: Shadowmeter Questions - by Chuck Schwark - 10-04-2013, 10:26 AM
RE: Shadowmeter Questions - by Tom Hamilton - 10-07-2013, 12:46 PM
RE: Shadowmeter Questions - by Jamie - 10-07-2013, 01:11 PM
