Philco 640 Cabinet Refinishing Chronicles
#52
Looking good Icon_thumbup Odd, I use red Solo cups all the time. Maybe the solvents in the Pore-O-Pac are different than Constantines ? I'd apply more grain filler before bothering to do any sanding.
RE: Philco 640 Cabinet Refinishing Chronicles - by Bob Andersen - 10-04-2013, 05:03 PM
Users browsing this thread: 36 Guest(s)
Philco 91 Tuning Condenser
There are currently 8748 online users. [Complete List]
» 3 Member(s) | 8745 Guest(s)
