Can Anyone ID this radio?
Mystery is solved... the name is stamped on the radio..
DeJur Corp.. NY, NY, along with several pat nos..
That would explain the DJA on the dial too...Anyone ever heard of them? Radio Museum says they made some kind of amp in 1926. No other info.
Can Anyone ID this radio? - by Jamie - 09-24-2013, 08:37 PM
RE: Can Anyone ID this radio? - by murf - 09-24-2013, 09:00 PM
RE: Can Anyone ID this radio? - by Jamie - 09-24-2013, 09:12 PM
RE: Can Anyone ID this radio? - by sam - 09-24-2013, 11:01 PM
RE: Can Anyone ID this radio? - by morzh - 09-25-2013, 11:11 AM
RE: Can Anyone ID this radio? - by Arran - 09-25-2013, 10:46 PM
RE: Can Anyone ID this radio? - by BrendaAnnD - 09-25-2013, 11:01 PM
RE: Can Anyone ID this radio? - by w4rtc - 09-25-2013, 11:16 PM
RE: Can Anyone ID this radio? - by Arran - 09-26-2013, 12:26 AM
RE: Can Anyone ID this radio? - by Jamie - 09-26-2013, 06:15 AM
RE: Can Anyone ID this radio? - by Jamie - 10-04-2013, 03:45 PM
RE: Can Anyone ID this radio? - by Jamie - 10-04-2013, 07:40 PM
RE: Can Anyone ID this radio? - by sam - 10-04-2013, 09:26 PM
RE: Can Anyone ID this radio? - by morzh - 10-04-2013, 11:23 PM
RE: Can Anyone ID this radio? - by Arran - 10-05-2013, 02:28 AM
RE: Can Anyone ID this radio? - by Jamie - 10-05-2013, 01:13 PM
There are currently 2089 online users. [Complete List]
» 1 Member(s) | 2088 Guest(s)
