Stewart-Warner 950 battery set
The AWA Old Timers Bulletin had an article on constructing a solid state substitute for an audio interstate transformer from I thing around 2003 or so, it's online someplace.
Stewart-Warner 950 battery set - by BrendaAnnD - 09-30-2013, 11:34 PM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 12:17 AM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 11:35 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-01-2013, 11:24 PM
RE: Stewart-Warner 950 battery set - by marty - 10-02-2013, 10:30 AM
RE: Stewart-Warner 950 battery set - by sam - 10-04-2013, 11:57 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 05:29 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 08:55 AM
RE: Stewart-Warner 950 battery set - by marty - 10-05-2013, 10:49 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-06-2013, 03:45 AM
There are currently 5005 online users. [Complete List]
» 3 Member(s) | 5002 Guest(s)
