Stewart-Warner 950 battery set
Well, the radio is essentially finished. I could not remove the third transformer from it's can. Of course, after getting molten tar all over my fingers, I also sort of lost the will to fight it anymore. I mounted my replacement transformer on top of the chassis. I also mounted a single solder lug on which to connect my feedback loop. It works pretty well now. Still need to get the proper tube in there so that there's a balance between the two outputs.
By the way.. you know those pain charts you see in the doctor's office? The ones with the faces numbered 1 to 10? Well, in case there are some of you out there that have yet to experience it (and I don't recommend it), having your fingers coated in molten tar is about a 15.. with a screaming face..Icon_eekIcon_eek
Stewart-Warner 950 battery set - by BrendaAnnD - 09-30-2013, 11:34 PM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 12:17 AM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 11:35 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-01-2013, 11:24 PM
RE: Stewart-Warner 950 battery set - by marty - 10-02-2013, 10:30 AM
RE: Stewart-Warner 950 battery set - by sam - 10-04-2013, 11:57 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 05:29 AM
RE: Stewart-Warner 950 battery set - by BrendaAnnD - 10-05-2013, 05:41 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 08:55 AM
RE: Stewart-Warner 950 battery set - by marty - 10-05-2013, 10:49 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-06-2013, 03:45 AM
There are currently 5384 online users. [Complete List]
» 5 Member(s) | 5379 Guest(s)
AvatarAvatarAvatarAvatar
