Something I recommend every collector have at their disposal is a Tube Substitution Guide. They are plentiful and cheap. You would be suprised at how many valid substitutions there are.
Also good to have are Receiving Tube Manuals. Personally, I use an RC-17 (1954) and an RC-30 (1960s).
The RC 17 covers the earlier tube well while the RC-30 covers all the newer stuff.
tube - by sam - 10-02-2013, 09:06 PM
RE: tube - by morzh - 10-02-2013, 09:15 PM
RE: tube - by Eric Adams - 10-03-2013, 09:21 PM
RE: tube - by klondike98 - 10-04-2013, 11:27 AM
RE: tube - by sam - 10-04-2013, 12:01 PM
RE: tube - by Eric Adams - 10-04-2013, 08:43 PM
RE: tube - by TA Forbes - 10-06-2013, 02:32 PM
RE: tube - by exray - 10-06-2013, 09:28 PM
RE: tube - by Eric Adams - 10-06-2013, 09:54 PM
RE: tube - by sam - 10-06-2013, 10:45 PM
RE: tube - by exray - 10-07-2013, 07:25 AM
RE: tube - by Ron Ramirez - 10-07-2013, 08:59 AM
RE: tube - by Eric Adams - 10-07-2013, 09:29 AM
RE: tube - by Ron Ramirez - 10-07-2013, 09:50 AM
RE: tube - by marty - 10-07-2013, 10:01 AM
RE: tube - by sam - 10-07-2013, 12:54 PM
RE: tube - by Ron Ramirez - 10-07-2013, 01:02 PM
RE: tube - by TA Forbes - 10-07-2013, 04:30 PM
RE: tube - by Eric Adams - 10-07-2013, 04:34 PM
RE: tube - by Jamie - 10-07-2013, 07:15 PM
There are currently 9767 online users. [Complete List]
» 3 Member(s) | 9764 Guest(s)
