Beautiful and highly desirable INGRAHAM CABINET!
Half a Mae West with a crack in her ***. Chassis plays Ok but not a great playing set, Emersom had some sleepers but I think with the power cord on this one it could be electrifying.
There are currently 4856 online users. [Complete List]
» 3 Member(s) | 4853 Guest(s)
