Ease up exray Icon_smile, I don't have every tube that I need at hand and If I'm in the middle of a restoration and in need of a tube, I'll go with a substitute. At least until I can order the correct one. Also, I don't like to wait 2 to 3 weeks for a tube, so Bob is not on the top of my list. Try AES.Icon_thumbup
Eric
The Villages, FL
tube - by sam - 10-02-2013, 09:06 PM
RE: tube - by morzh - 10-02-2013, 09:15 PM
RE: tube - by Eric Adams - 10-03-2013, 09:21 PM
RE: tube - by klondike98 - 10-04-2013, 11:27 AM
RE: tube - by sam - 10-04-2013, 12:01 PM
RE: tube - by Eric Adams - 10-04-2013, 08:43 PM
RE: tube - by TA Forbes - 10-06-2013, 02:32 PM
RE: tube - by exray - 10-06-2013, 09:28 PM
RE: tube - by Eric Adams - 10-06-2013, 09:54 PM
RE: tube - by sam - 10-06-2013, 10:45 PM
RE: tube - by exray - 10-07-2013, 07:25 AM
RE: tube - by Ron Ramirez - 10-07-2013, 08:59 AM
RE: tube - by Eric Adams - 10-07-2013, 09:29 AM
RE: tube - by Ron Ramirez - 10-07-2013, 09:50 AM
RE: tube - by marty - 10-07-2013, 10:01 AM
RE: tube - by sam - 10-07-2013, 12:54 PM
RE: tube - by Ron Ramirez - 10-07-2013, 01:02 PM
RE: tube - by TA Forbes - 10-07-2013, 04:30 PM
RE: tube - by Eric Adams - 10-07-2013, 04:34 PM
RE: tube - by Jamie - 10-07-2013, 07:15 PM
There are currently 9948 online users. [Complete List]
» 2 Member(s) | 9946 Guest(s)
