Power Supply 37-89
The socket was still wired for 5Y4G (guess the other tube was just stuck in there). I am getting correct voltages but still not picking up any signals except switches and other interference.
Thanks for the tip, Herb
Power Supply 37-89 - by Herb Kennedy - 10-02-2013, 09:24 PM
RE: Power Supply 37-89 - by morzh - 10-03-2013, 10:17 AM
RE: Power Supply 37-89 - by Herb Kennedy - 10-03-2013, 08:46 PM
RE: Power Supply 37-89 - by Herb Kennedy - 10-07-2013, 01:13 PM
There are currently 10954 online users. [Complete List]
» 2 Member(s) | 10952 Guest(s)
