Philco 40-130T
OK--I went to Alphatronix---what a joke---a lot of stuff, but nothing that I can use. I guess I will have to go online to order, so be it----questions do arise though, the electrolytics on this Philco are 4 mfd 400v and 12mfd also 400v--how close do I have to be to these values for proper operation ? is over value ok ? coupling caps do not seem to be a problem getting in value range, but electrolytics are I will probably deal with AES--and work on chassis clean up etc until parts arrive--don't get it parts should be locally available
Philco 40-130T - by wireless - 08-17-2013, 07:25 PM
RE: Philco 40-130T - by Ron Ramirez - 08-17-2013, 09:24 PM
RE: Philco 40-130T - by wireless - 08-18-2013, 02:07 AM
RE: Philco 40-130T - by codefox1 - 08-18-2013, 10:45 AM
RE: Philco 40-130T - by Paul Philco322 - 08-18-2013, 11:16 AM
RE: Philco 40-130T - by wireless - 08-19-2013, 11:01 AM
RE: Philco 40-130T - by Paul Philco322 - 08-24-2013, 09:41 PM
RE: Philco 40-130T - by wireless - 08-27-2013, 05:26 PM
RE: Philco 40-130T - by wireless - 08-29-2013, 03:54 PM
RE: Philco 40-130T - by audiomagnate - 08-29-2013, 08:53 PM
RE: Philco 40-130T - by wireless - 08-29-2013, 09:11 PM
RE: Philco 40-130T - by Paul Philco322 - 09-04-2013, 08:56 PM
RE: Philco 40-130T - by Ron Ramirez - 09-05-2013, 05:42 AM
RE: Philco 40-130T - by audiomagnate - 09-05-2013, 12:20 PM
RE: Philco 40-130T - by wireless - 09-13-2013, 05:41 PM
RE: Philco 40-130T - by Art Hoch - 09-19-2013, 05:58 PM
RE: Philco 40-130T - by Art Hoch - 09-19-2013, 06:00 PM
RE: Philco 40-130T - by Ron Ramirez - 09-19-2013, 07:31 PM
RE: Philco 40-130T - by jerryhawthorne - 09-19-2013, 07:53 PM
RE: Philco 40-130T - by Radioroslyn - 09-19-2013, 10:18 PM
RE: Philco 40-130T - by wireless - 09-21-2013, 05:41 PM
RE: Philco 40-130T - by wireless - 10-03-2013, 01:31 PM
RE: Philco 40-130T - by wireless - 10-04-2013, 05:17 PM
RE: Philco 40-130T - by jerryhawthorne - 10-04-2013, 06:06 PM
RE: Philco 40-130T - by Jamie - 10-04-2013, 06:09 PM
RE: Philco 40-130T - by wireless - 10-04-2013, 06:52 PM
RE: Philco 40-130T - by wireless - 10-06-2013, 05:39 PM
RE: Philco 40-130T - by jerryhawthorne - 10-06-2013, 05:58 PM
RE: Philco 40-130T - by wireless - 10-07-2013, 04:11 PM
RE: Philco 40-130T - by Warren - 10-07-2013, 05:55 PM
RE: Philco 40-130T - by George Kirk - 10-08-2013, 01:44 PM
RE: Philco 40-130T - by wireless - 10-10-2013, 11:07 AM
RE: Philco 40-130T - by wireless - 10-10-2013, 05:44 PM
RE: Philco 40-130T - by George Kirk - 10-10-2013, 07:23 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 02:06 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 03:10 PM
RE: Philco 40-130T - by Jamie - 10-23-2013, 06:16 PM
RE: Philco 40-130T - by jerryhawthorne - 10-23-2013, 07:30 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 10:36 PM
RE: Philco 40-130T - by Arran - 10-23-2013, 11:07 PM
RE: Philco 40-130T - by Chuck Schwark - 10-24-2013, 09:16 AM
RE: Philco 40-130T - by wireless - 10-24-2013, 04:52 PM
RE: Philco 40-130T - by Chuck Schwark - 10-24-2013, 05:32 PM
RE: Philco 40-130T - by Arran - 10-25-2013, 02:17 AM
RE: Philco 40-130T - by wireless - 10-25-2013, 03:03 PM
RE: Philco 40-130T - by wireless - 11-08-2013, 07:12 PM
RE: Philco 40-130T - by wireless - 11-17-2013, 09:19 PM
RE: Philco 40-130T - by BrendaAnnD - 11-18-2013, 02:44 AM
RE: Philco 40-130T - by wireless - 11-18-2013, 12:07 PM
RE: Philco 40-130T - by wireless - 11-23-2013, 08:58 PM
RE: Philco 40-130T - by wireless - 12-04-2013, 01:35 PM
RE: Philco 40-130T - by wireless - 12-13-2013, 10:59 PM
RE: Philco 40-130T - by wireless - 12-22-2013, 05:35 PM
RE: Philco 40-130T - by jerryhawthorne - 12-22-2013, 05:41 PM
RE: Philco 40-130T - by wireless - 12-22-2013, 05:51 PM
RE: Philco 40-130T - by jerryhawthorne - 12-22-2013, 06:39 PM
There are currently 9455 online users. [Complete List]
» 3 Member(s) | 9452 Guest(s)
