Intermediate Frequency Adjustment ?
I'am preparing to adjust the I.F.s on my philco model 144. Reading the procedure it doesn't say if you should do them in the order of 1st,2nd&3rd. Is that the order I should use?
Thanks
Intermediate Frequency Adjustment ? - by KCMike - 10-08-2013, 09:09 PM
There are currently 10209 online users. [Complete List]
» 3 Member(s) | 10206 Guest(s)
