Model 20 volume control broken
Yes, it was a two part control, and was in a couple of models from that year. They are tough but not impossible to find, I know of no aftermarket controls that apply.
Check with the Playthings of the Past site, also Mark Oppats Oldradioparts.net site.
Model 20 volume control broken - by SteveJB - 10-08-2013, 09:45 PM
RE: Model 20 volume control broken - by TA Forbes - 10-09-2013, 12:54 PM
RE: Model 20 volume control broken - by SteveJB - 10-09-2013, 07:06 PM
RE: Model 20 volume control broken - by morzh - 10-10-2013, 09:29 AM
There are currently 7253 online users. [Complete List]
» 2 Member(s) | 7251 Guest(s)
