Happy Camper Tonight!
I just got home with the 90 and it's a beauty. I asked if he knew the local club president who I met at a swap meet. Turns out that is the guy he bought it from 20 years ago.
It has the 45 tubes so it must be one of the first ones. The transformer looks huge.
-Phil
Happy Camper Tonight! - by Uffda - 03-30-2008, 09:59 PM
[No subject] - by Ron Ramirez - 03-30-2008, 11:34 PM
[No subject] - by Uffda - 03-31-2008, 12:55 AM
[No subject] - by exray - 03-31-2008, 07:51 AM
[No subject] - by Doug Houston - 04-01-2008, 09:17 PM
[No subject] - by Ron Ramirez - 04-01-2008, 10:07 PM
[No subject] - by Uffda - 04-01-2008, 10:36 PM
There are currently 8908 online users. [Complete List]
» 2 Member(s) | 8906 Guest(s)
