Beautiful and highly desirable INGRAHAM CABINET!
Brenda,
You are right, at a closer look it is the antenna coil. Oh, my Gosh! This thing looks like it has been lifted from the ocean floor after 40 years. If it works, I'll be a monkey's uncle.
There are currently 9882 online users. [Complete List]
» 3 Member(s) | 9879 Guest(s)
