Model 45 Dial Question
The printing is usually on the back of the dial. The front has a matte finish so that you can write on it with a pencil to add station call letters, etc. At least this is true of the model 89 dial which looks very similar to what you have.
Why would you want to remove the plastic dial to clean it? It looks very presentable as is and I would certainly be wary of trying to remove it as I believe it is riveted to the metal pulley assy.
Model 45 Dial Question - by Jamie - 10-11-2013, 06:17 PM
RE: Model 45 Dial Question - by Mondial - 10-11-2013, 09:34 PM
RE: Model 45 Dial Question - by marty - 10-11-2013, 09:44 PM
RE: Model 45 Dial Question - by Jamie - 10-11-2013, 09:49 PM
RE: Model 45 Dial Question - by GarySP - 10-11-2013, 10:03 PM
There are currently 4553 online users. [Complete List]
» 1 Member(s) | 4552 Guest(s)
