Model 45 Dial Question
I wouldn't touch it!!! Perhaps a blast of air to dislodge any dust bunnies, but nothing more. It adds a touch of character to the set if it looks "period mature". Clean the bulb behind it though, that may help a little. Take care, Gary
Model 45 Dial Question - by Jamie - 10-11-2013, 06:17 PM
RE: Model 45 Dial Question - by Mondial - 10-11-2013, 09:34 PM
RE: Model 45 Dial Question - by marty - 10-11-2013, 09:44 PM
RE: Model 45 Dial Question - by Jamie - 10-11-2013, 09:49 PM
RE: Model 45 Dial Question - by GarySP - 10-11-2013, 10:03 PM
There are currently 10982 online users. [Complete List]
» 2 Member(s) | 10980 Guest(s)
