edison radio
Sam, it doesn't appear to be listed in N/A. Jump on that radio! I love the styling and the dual chassis. Looks to be in great shape.
Regards, Jerry
Edit: this link might give you a little more information. Dual 45s!
http://www.radiomuseum.org/r/edison_r4.html
edison radio - by sam - 10-13-2013, 06:17 PM
RE: edison radio - by jerryhawthorne - 10-13-2013, 06:58 PM
RE: edison radio - by Jayce - 10-13-2013, 07:14 PM
RE: edison radio - by jerryhawthorne - 10-13-2013, 07:51 PM
RE: edison radio - by Radioroslyn - 10-13-2013, 09:58 PM
RE: edison radio - by Skip - 10-14-2013, 01:34 AM
RE: edison radio - by morzh - 10-14-2013, 11:17 AM
RE: edison radio - by TA Forbes - 10-14-2013, 03:15 PM
RE: edison radio - by SteveJB - 10-14-2013, 07:15 PM
RE: edison radio - by jerryhawthorne - 10-14-2013, 07:26 PM
There are currently 5881 online users. [Complete List]
» 2 Member(s) | 5879 Guest(s)
