Speaker Connection to Ground in 42-350
Hope I'm not speaking out of line since I haven't seen this particular set, but going to assume that it shouldn't be too critical where you connect the wire since it's an audio return path. Lead dress can make a difference in other stages but I'm thinking for this you should be fine at any convenient ground point.
[No subject] - by TonyJSenior - 04-04-2008, 11:47 AM
Eico 232 VTVM Schematic
There are currently 9461 online users. [Complete List]
» 1 Member(s) | 9460 Guest(s)
