edison radio
Sam
They are nice TRF's when done. The PP 45's do make it sound good. I have restored two with the Phonograph. The power transformers are weak and tend to have problems. I had to have a new one wound. Replace both power resistors in the amp chassis as they tend to be open. Plenty of room under the chassis to work and place new caps without opening the cans.
Good luck
Skip
edison radio - by sam - 10-13-2013, 06:17 PM
RE: edison radio - by jerryhawthorne - 10-13-2013, 06:58 PM
RE: edison radio - by Jayce - 10-13-2013, 07:14 PM
RE: edison radio - by jerryhawthorne - 10-13-2013, 07:51 PM
RE: edison radio - by Radioroslyn - 10-13-2013, 09:58 PM
RE: edison radio - by Skip - 10-14-2013, 01:34 AM
RE: edison radio - by morzh - 10-14-2013, 11:17 AM
RE: edison radio - by TA Forbes - 10-14-2013, 03:15 PM
RE: edison radio - by SteveJB - 10-14-2013, 07:15 PM
RE: edison radio - by jerryhawthorne - 10-14-2013, 07:26 PM
There are currently 5720 online users. [Complete List]
» 2 Member(s) | 5718 Guest(s)
