46-350 Electrolytic Cap Explosion?
What is the size of the cap. I saved the "can" (it phenol/bakalite) from a motor starter cap that is 1 1/2" rd by 2 3/4" high that could be painted aluminim. Would not be perfect match but would work if you figure some way to mount if not clamped on. PL
[No subject] - by justlrnin - 02-27-2008, 09:32 PM
[No subject] - by Ron Ramirez - 02-27-2008, 11:44 PM
[No subject] - by Texasrocker - 02-28-2008, 01:32 AM
[No subject] - by Chuck Schwark - 02-28-2008, 09:58 AM
[No subject] - by justlrnin - 02-28-2008, 01:07 PM
[No subject] - by Chuck Schwark - 02-28-2008, 01:15 PM
[No subject] - by justlrnin - 02-28-2008, 03:33 PM
[No subject] - by Guest - 02-28-2008, 06:32 PM
[No subject] - by Texasrocker - 02-29-2008, 03:34 AM
[No subject] - by FStephenMasek - 04-01-2008, 11:33 AM
[No subject] - by justlrnin - 04-01-2008, 12:35 PM
[No subject] - by Alan Douglas - 04-01-2008, 08:19 PM
[No subject] - by FStephenMasek - 04-02-2008, 10:42 AM
[No subject] - by planigan - 04-03-2008, 12:38 AM
[No subject] - by exray - 04-03-2008, 07:37 AM
[No subject] - by justlrnin - 04-03-2008, 12:15 PM
[No subject] - by planigan - 04-03-2008, 11:46 PM
[No subject] - by planigan - 04-04-2008, 07:54 PM
Eico 232 VTVM Schematic
There are currently 9284 online users. [Complete List]
» 2 Member(s) | 9282 Guest(s)
