Loktal tubes
I've a question. It has probably been answered before, but here goes:
Why do loctal tubes have designations like 7B7 or 14B7, when in actuality the filament voltages are 6.3 and 12.6, respectively? Were they running out of letter designations for 6 and 12 volt tubes by that time? I note that ones like 35Y4 use the standard filament voltages.
Loktal tubes - by BrendaAnnD - 10-15-2013, 02:01 AM
RE: Loktal tubes - by Mondial - 10-15-2013, 08:17 AM
RE: Loktal tubes - by BrendaAnnD - 10-15-2013, 03:14 PM
RE: Loktal tubes - by codefox1 - 10-15-2013, 03:53 PM
RE: Loktal tubes - by Arran - 10-15-2013, 11:16 PM
