37-116 Switch Wafer Illustrations
I do not have one of these sets, so I am not trying to correct a problem. I am planning to get one of these sets when one becomes available. I am trying to make sure that my schematic is correct if and when I get a set to restore. The schematic I had was poor copy and difficult to read. I think I have the switch tabs mentioned in my first post correct unless I could not read the Rider's schematic correctly. I just wanted someone with a good copy of the schematic to look at their copy and see if the switch tabs that I identified are indeed the ones that are on the front side of the wafers according to their schematic (they are shown with dashed lines on the schematic).
Thanks for responding.
37-116 Switch Wafer Illustrations - by Joeztech - 10-11-2013, 05:12 PM
RE: 37-116 Switch Wafer Illustrations - by morzh - 10-14-2013, 10:55 AM
RE: 37-116 Switch Wafer Illustrations - by Joeztech - 10-15-2013, 07:42 AM
RE: 37-116 Switch Wafer Illustrations - by morzh - 10-15-2013, 03:36 PM
There are currently 7006 online users. [Complete List]
» 1 Member(s) | 7005 Guest(s)
