My Next Project - worse than the last?
Nice work so far. Just a suggestion...if you have a soup pot large enough to place the cabinet in try steaming the wood before attempting to bend it back. Put about a half inch of water in the pot, then a pie plate to keep the cabinet from coming in contact with the water. Add the cabinet and slowly bring the water to a slow boil with the lid on the pot. Ten or so minutes should rehydrate the wood so it will flex easier. Take care, Gary
My Next Project - worse than the last? - by Jamie - 10-15-2013, 03:12 PM
RE: My Next Project - worse than the last? - by GarySP - 10-16-2013, 05:01 PM
Users browsing this thread: 21 Guest(s)
91H Code 126 Restore
