What should I do with this?
Thank you for the responses, I don't know why I always have trouble with pics. I had individually clicked each img. then hit ctrl-v and they showed up as four seperate imgs in the post so I hit post and seen that only one was viewable. I'll try to get it right next time.
The cabinet is very solid with only a couple small areas that will need veneer work. About that grill cloth. Seems to be a W- pattern. The dark on it is paint any ideas on if it can be removed?
If not I think I'll just live with it because it is in good condition. Oh yeah, the metal sliders will be going away.
What should I do with this? - by KCMike - 10-16-2013, 12:33 PM
RE: What should I do with this? - by Jamie - 10-16-2013, 01:22 PM
RE: What should I do with this? - by KCMike - 10-16-2013, 01:29 PM
RE: What should I do with this? - by ipwizard - 10-16-2013, 02:33 PM
RE: What should I do with this? - by Bob Andersen - 10-16-2013, 02:54 PM
RE: What should I do with this? - by KCMike - 10-16-2013, 06:26 PM
RE: What should I do with this? - by Jamie - 10-16-2013, 06:31 PM
RE: What should I do with this? - by KCMike - 10-16-2013, 08:37 PM
RE: What should I do with this? - by Jamie - 10-17-2013, 04:44 PM
RE: What should I do with this? - by KCMike - 10-17-2013, 04:54 PM
RE: What should I do with this? - by KCMike - 10-18-2013, 04:08 PM
RE: What should I do with this? - by Art Hoch - 10-20-2013, 06:08 PM
RE: What should I do with this? - by Skip - 10-20-2013, 06:41 PM
RE: What should I do with this? - by KCMike - 10-20-2013, 08:17 PM
RE: What should I do with this? - by EricS - 10-20-2013, 09:53 PM
RE: What should I do with this? - by KCMike - 10-20-2013, 10:31 PM
RE: What should I do with this? - by Arran - 10-21-2013, 01:41 AM
RE: What should I do with this? - by Art Hoch - 10-21-2013, 11:29 AM
RE: What should I do with this? - by Jamie - 10-21-2013, 11:43 AM
RE: What should I do with this? - by KCMike - 10-21-2013, 07:09 PM
RE: What should I do with this? - by Jamie - 10-21-2013, 07:20 PM
RE: What should I do with this? - by KCMike - 10-21-2013, 08:25 PM
RE: What should I do with this? - by PT57 - 10-21-2013, 10:05 PM
RE: What should I do with this? - by PT57 - 10-21-2013, 10:08 PM
RE: What should I do with this? - by KCMike - 10-21-2013, 10:40 PM
RE: What should I do with this? - by EricS - 10-22-2013, 08:19 PM
RE: What should I do with this? - by KCMike - 10-22-2013, 08:47 PM
RE: What should I do with this? - by EricS - 10-23-2013, 07:38 PM
RE: What should I do with this? - by KCMike - 10-24-2013, 12:25 PM
RE: What should I do with this? - by codefox1 - 10-30-2013, 03:11 PM
RE: What should I do with this? - by murf - 12-31-2013, 09:43 PM
RE: What should I do with this? - by KCMike - 05-02-2014, 01:39 PM
RE: What should I do with this? - by TheBakery - 05-02-2014, 02:10 PM
RE: What should I do with this? - by KCMike - 05-02-2014, 02:59 PM
RE: What should I do with this? - by OldRestorer - 05-02-2014, 03:10 PM
RE: What should I do with this? - by PhilcoMike - 05-02-2014, 03:40 PM
RE: What should I do with this? - by Jamie - 05-02-2014, 04:12 PM
RE: What should I do with this? - by KCMike - 05-02-2014, 05:13 PM
RE: What should I do with this? - by TA Forbes - 05-02-2014, 09:00 PM
RE: What should I do with this? - by EricS - 05-02-2014, 09:25 PM
There are currently 10195 online users. [Complete List]
» 3 Member(s) | 10192 Guest(s)
