Pilot lamp blows out
Two things come to mind. Bad rectifier tube or wiring/socket on lamp. Lamp can't be grounded.
Pilot lamp blows out - by Buzz - 10-16-2013, 07:27 PM
RE: Pilot lamp blows out - by Radioroslyn - 10-16-2013, 08:06 PM
RE: Pilot lamp blows out - by BrendaAnnD - 10-16-2013, 08:25 PM
RE: Pilot lamp blows out - by Buzz - 10-16-2013, 09:04 PM
RE: Pilot lamp blows out - by LASJayhawk - 10-16-2013, 10:47 PM
RE: Pilot lamp blows out - by Buzz - 10-17-2013, 10:37 AM
RE: Pilot lamp blows out - by LASJayhawk - 10-17-2013, 01:14 PM
RE: Pilot lamp blows out - by Buzz - 10-21-2013, 07:28 PM
RE: Pilot lamp blows out - by Randy H. - 11-12-2013, 07:36 PM
