Pilot lamp blows out
Is the 10.6 VAC too high? Isnt it suppose to be about 4 volts.. its a #47 lamp.
I'll clean the rectiifer tube, also have ordered a new one,,
will let you know..
thanks
Buzz
Pilot lamp blows out - by Buzz - 10-16-2013, 07:27 PM
RE: Pilot lamp blows out - by Radioroslyn - 10-16-2013, 08:06 PM
RE: Pilot lamp blows out - by BrendaAnnD - 10-16-2013, 08:25 PM
RE: Pilot lamp blows out - by Buzz - 10-16-2013, 09:04 PM
RE: Pilot lamp blows out - by LASJayhawk - 10-16-2013, 10:47 PM
RE: Pilot lamp blows out - by Buzz - 10-17-2013, 10:37 AM
RE: Pilot lamp blows out - by LASJayhawk - 10-17-2013, 01:14 PM
RE: Pilot lamp blows out - by Buzz - 10-21-2013, 07:28 PM
RE: Pilot lamp blows out - by Randy H. - 11-12-2013, 07:36 PM
There are currently 10898 online users. [Complete List]
» 3 Member(s) | 10895 Guest(s)
