Philco 112 Lowboy restoration (caution, lots of images)
Hi,
I was wondering if there would have been room inside the can, right inder all the tar to add the new caps?
On my Philco 20, I removed very little of the tar inside the square can, then added the new caps underneath the tar, but mounted to the bottom terminals. That saved me a lot of trouble/mess, rather then emptying the whole can out.
Just a thought.. great job though coming along well.
Gary.
[No subject] - by PhilcoPhil - 03-27-2008, 05:49 PM
[No subject] - by Ron Ramirez - 03-27-2008, 05:51 PM
[No subject] - by gary rabbitt - 04-06-2008, 01:32 PM
[No subject] - by BDM - 04-06-2008, 06:15 PM
[No subject] - by audin - 04-08-2008, 02:38 PM
[No subject] - by audin - 04-08-2008, 02:41 PM
[No subject] - by audin - 04-08-2008, 02:59 PM
There are currently 7103 online users. [Complete List]
» 1 Member(s) | 7102 Guest(s)
