Philco Model 20 volume control operation
The volume control should be a dual pot. One section, as Keith described pads down the antenna input and decreases the signal level. The second section adjusts the bias on the RF amplifier tubes and sets the level of signal amplification.
It sounds as if the second pot section on your radio is not working properly. This pot is connected as a voltage divider, connected as part of the large wirewound resistor on the side of the chassis. If you connect a voltmeter to the sliding contact of this pot section, you should see the voltage change by several volts as the pot is rotated. If you see no change, then either the pot is bad or there is an open section in the wirewound bias resistor.
If working properly you should have good control of volume level, even on a fairly strong signal.
RE: Philco Model 20 volume control operation - by Mondial - 10-17-2013, 08:12 PM
There are currently 10438 online users. [Complete List]
» 4 Member(s) | 10434 Guest(s)
AvatarAvatarAvatarAvatar
