Philco Model 20 volume control operation
Thanks. I will have some time this weekend to check what each of you has said.
RE: Philco Model 20 volume control operation - by SteveJB - 10-17-2013, 08:49 PM
There are currently 9780 online users. [Complete List]
» 3 Member(s) | 9777 Guest(s)
