restoring a 41-265 help please.
You might also find that your 1941 model has brittle rubber wiring which needs to be replaced. I justs bought a 41-250, and every wire will have to be changed. I like the radio, and would never expend the effort and time required to replace every wire on any radio I did not really like.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
restoring a 41-265 help please. - by Guest - 04-07-2008, 02:35 AM
[No subject] - by exray - 04-07-2008, 08:05 AM
[No subject] - by FStephenMasek - 04-07-2008, 04:31 PM
Eico 232 VTVM Schematic
There are currently 7224 online users. [Complete List]
» 1 Member(s) | 7223 Guest(s)
