Philco 46-1203
Jeff, welcome to the Phorum!! From the schematic it looks like C14 should be a single electrolytic (15mF) but C19 has two caps , 40 and 10 mF. Its possible your cap is a replacement where only one leg was used or it's the original C19 where one of the caps failed, the lead was cut and another electrolytic is tacked into the circuit elsewhere. If you order the schematic from Chuck Schwark , Philcorepairbench.com there will be more info than the schematic from Nostalgia Air. Others with specific experience with this model may have other thoughts.
Philco 46-1203 - by Colorado Jeff - 10-18-2013, 12:11 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 05:07 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-18-2013, 07:28 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 08:35 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 09:53 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 10:44 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:03 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:06 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 12:30 PM
RE: Philco 46-1203 - by codefox1 - 10-30-2013, 03:00 PM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 06:49 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 01:13 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 02:31 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 02:38 PM
RE: Philco 46-1203 - by skyscraper - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 04:21 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 04:27 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-08-2014, 11:19 PM
RE: Philco 46-1203 - by wa2ise - 02-09-2014, 01:09 AM
There are currently 9728 online users. [Complete List]
» 1 Member(s) | 9727 Guest(s)
