Philco Model 20 volume control operation
Hello SteveJB, later production of these 20's had dial lamps. Yours must be an earlier set. The lamp is easy to add to the dial, and it taps the tube filament wiring for power. Take care, Gary.
RE: Philco Model 20 volume control operation - by GarySP - 10-18-2013, 06:09 PM
There are currently 10312 online users. [Complete List]
» 1 Member(s) | 10311 Guest(s)
