Philco 46-1203
Looks like a replacement to me as there is no 50-30 mF cap in the schematic. You need to change out all the electrolytic and paper caps anyway. Check where it's connected to for confirmation it's C14. Replace out of tolerance resistors as you go as well.
Philco 46-1203 - by Colorado Jeff - 10-18-2013, 12:11 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 05:07 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-18-2013, 07:28 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 08:35 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 09:53 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 10:44 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:03 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:06 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 12:30 PM
RE: Philco 46-1203 - by codefox1 - 10-30-2013, 03:00 PM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 06:49 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 01:13 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 02:31 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 02:38 PM
RE: Philco 46-1203 - by skyscraper - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 04:21 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 04:27 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-08-2014, 11:19 PM
RE: Philco 46-1203 - by wa2ise - 02-09-2014, 01:09 AM
Philco 91 Tuning Condenser
