Another Brand Z sneaks into the collection.
Another brand Z has snuck into my collection. It is a model 10-S-589 and even though it isn't perfect, I liked the looks and the price was right. Only major issues, I need to reglue one of the veneer strips back onto the grill and the original phonograph was replaced sometime with a V-M four speed changer. (Maybe that isn't so bad as the original changers are so-so at best.) No major hacking done on the cabinet, so I could put an original changer back in if I wanted. One thing that did get me is the speaker, it's a beast compared to the one in my 10-S-599 from the same year! Icon_eek
Another Brand Z sneaks into the collection. - by Jayce - 10-18-2013, 08:55 PM
There are currently 4945 online users. [Complete List]
» 1 Member(s) | 4944 Guest(s)
