38-60B or a 40-130T
I am looking at these two radios. Seller wants twice as much for the 38-60B. Photo finish on the radio is good. Rest of cabinet has some scatches. Cabinet on 40-130T is beautiful. At this time I can only go for one of them. Any input would be appreciated.
Neither have been recapped.
38-60B or a 40-130T - by RoyG - 10-20-2013, 11:07 AM
RE: 38-60B or a 40-130T - by Radioroslyn - 10-20-2013, 12:57 PM
RE: 38-60B or a 40-130T - by wireless - 10-20-2013, 01:38 PM
Philco 91 Tuning Condenser
There are currently 5224 online users. [Complete List]
» 2 Member(s) | 5222 Guest(s)
