Just bought a Philco B-1756
I bought a Philco B-1756 yesterday ($50, and it came with the manual with a copyright date of 1953).
I suspect I will need a cartridge - does anyone know a good source for the "Phonorama reproducers (ivory colored case)?
[Image: http://i269.photobucket.com/albums/jj77/...closed.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...56open.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Just bought a Philco B-1756 - by FStephenMasek - 04-07-2008, 10:56 PM
RE: Just bought a Philco B-1756 - by 7estatdef - 04-26-2013, 09:34 PM
RE: Just bought a Philco B-1756 - by Ron Ramirez - 04-12-2014, 10:41 PM
RE: Just bought a Philco B-1756 - by Arran - 05-21-2014, 10:43 PM
[No subject] - by Doug Houston - 04-09-2008, 10:48 PM
[No subject] - by FStephenMasek - 05-27-2008, 01:37 AM
[No subject] - by Don Lind - 05-27-2008, 04:17 PM
Philco 91 Tuning Condenser
