42-380 Cabinet Clean-up / Not Strip
I know I saw a thread on here recently about how to clean up a gunky cabinet that wasn't quite bad enough for a refinish. But I've been looking for hours and I can't seem to find it. It advised to clean up the cabinet with GoJo and then, I think, rub it down with Howard's Finish Restorer.
I did the GoJo routine, getting into all the nooks and crannies with a toothbrush, then I wiped it down with a clean cotton cloth. But I'm hesitant to go on to the next phase because the surface now has a waxy smudginess to it. Clearly there's still GoJo residoo-doo. How do I go about removing this without damaging the finish? Water? Alcohol? Paint thinner?
Also, there's a small cigarette burn on the top surface. Any advice as how to minimize or eliminate it?
42-380 Cabinet Clean-up / Not Strip - by PT57 - 10-20-2013, 06:14 PM
RE: 42-380 Cabinet Clean-up / Not Strip - by PT57 - 10-20-2013, 06:50 PM
RE: 42-380 Cabinet Clean-up / Not Strip - by PT57 - 10-20-2013, 06:52 PM
RE: 42-380 Cabinet Clean-up / Not Strip - by PT57 - 10-20-2013, 07:16 PM
RE: 42-380 Cabinet Clean-up / Not Strip - by PT57 - 10-21-2013, 11:20 AM
91H Code 126 Restore
There are currently 2749 online users. [Complete List]
» 2 Member(s) | 2747 Guest(s)
