Ohms readings on speaker output transformer
The alignment was done according to specs. This is being powered by a battery eliminator kit from Antique Electronic Supply. The "A" voltage for the filaments is spot on @ 1.5 V. The 90 V "B" voltages Measures 87 V.
How to you measure impedance? or can you?
Buzz
RE: Ohms readings on speaker output transformer - by Buzz - 10-21-2013, 07:37 AM
There are currently 7486 online users. [Complete List]
» 1 Member(s) | 7485 Guest(s)
