Philco 112 Lowboy restoration (caution, lots of images)
There wasn't enough room in the can for replacements without some major excavation. And since i had to heat the mess anyway to get any of it out, i just heated it the whole way and pulled the whole mess out at once.
It is pretty easy. Just heat the sides while pulling lightly on the wires. At a certain point it will let go and the whole inside will pull out in one big piece.
[No subject] - by PhilcoPhil - 03-27-2008, 05:49 PM
[No subject] - by Ron Ramirez - 03-27-2008, 05:51 PM
[No subject] - by gary rabbitt - 04-06-2008, 01:32 PM
[No subject] - by BDM - 04-06-2008, 06:15 PM
[No subject] - by audin - 04-08-2008, 02:38 PM
[No subject] - by audin - 04-08-2008, 02:41 PM
[No subject] - by audin - 04-08-2008, 02:59 PM
