Philco 71 Cathedral chassis finish?
Well if you wanted something that looks kinda original I'd clean off the rust use bondo or spot putty for the pitting then some gray primer to match the original color and sheen.
Philco 71 Cathedral chassis finish? - by wbaradio - 10-20-2013, 09:10 AM
RE: Philco 71 Cathedral chassis finish? - by Radioroslyn - 10-21-2013, 05:58 PM
There are currently 10481 online users. [Complete List]
» 3 Member(s) | 10478 Guest(s)
