Bucket list find - McMurdo Masterpiece 1
It turns out I already have an ORIGINAL Masterpiece 1 cabinet. This same cabinet was made in Rockford Il by Peerless furniture and sold to both EH Scott and McMurdo Silver for about 1 year. Scott called his the ORLEANS and McMurdo called his the Sheraton Combination.
I found this cabinet 2 years ago in St Pete in a used furniture store as a shelving cabinet and had Kenny Richmond do a restoration on it. There were differences in where the speakers were mounted due to size differences. Many thanks to Gerry Steffens for the original cabinet brochure for MS.
[Image: http://i213.photobucket.com/albums/cc249...c1cce1.jpg]
[Image: http://i213.photobucket.com/albums/cc249...71af36.png]
RE: Bucket list find - McMurdo Masterpiece 1 - by y2kbruce - 10-21-2013, 08:04 PM
There are currently 6993 online users. [Complete List]
» 2 Member(s) | 6991 Guest(s)
