Good morning, all
I am still working on the chassis of my 48-1262. I feel that I am getting close, but I have two issues that need resolving: a hum with no reception and the oscillator test shows + voltage instead of -.
Trouble shooting guide points to bad C103A and B if abnormal hum is present, but these are new and were checked for correct capacitance. R102 was also a suspect, but it tests just fine.
Voltages are good except test point D is a little low. Voltages are correct on the 14AF7 as well. The oscillator coil test at 3.0 ohms instead of 3.8.
Any thoughts as to where I should check next? I only test equipment is a Fluke Multimeter.
48-1262 - by ke5yum - 10-08-2013, 01:14 PM
RE: 48-1262 - by klondike98 - 10-08-2013, 04:05 PM
RE: 48-1262 - by BrendaAnnD - 10-08-2013, 04:09 PM
RE: 48-1262 - by ke5yum - 10-09-2013, 07:42 AM
RE: 48-1262 - by ke5yum - 10-22-2013, 07:56 AM
RE: 48-1262 - by Radioroslyn - 10-22-2013, 06:05 PM
RE: 48-1262 - by Radioroslyn - 10-22-2013, 06:48 PM
RE: 48-1262 - by ke5yum - 10-23-2013, 08:05 AM
RE: 48-1262 - by ke5yum - 10-30-2013, 07:57 AM
RE: 48-1262 - by Radioroslyn - 10-30-2013, 08:15 PM
RE: 48-1262 - by ke5yum - 10-31-2013, 08:02 AM
RE: 48-1262 - by Radioroslyn - 10-31-2013, 04:53 PM
RE: 48-1262 - by ke5yum - 11-01-2013, 07:50 AM
RE: 48-1262 - by ke5yum - 12-13-2013, 09:16 AM
RE: 48-1262 - by Radioroslyn - 12-15-2013, 01:08 PM
RE: 48-1262 - by ke5yum - 12-18-2013, 09:37 AM
RE: 48-1262 - by klondike98 - 12-18-2013, 10:03 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
