Today's Antique Show Finds...
The Philco is a 38-60. I like it, but I think it's photofinish on the front. It's in decent shape though. The Crosley is a 547 Quiktune Fiver. The dial works like a telephone dial.
Today's Antique Show Finds... - by Jamie - 10-20-2013, 09:21 PM
RE: Today's Antique Show Finds... - by sam - 10-20-2013, 09:47 PM
RE: Today's Antique Show Finds... - by Jamie - 10-21-2013, 10:15 AM
RE: Today's Antique Show Finds... - by Arran - 10-21-2013, 09:23 PM
RE: Today's Antique Show Finds... - by Jamie - 10-22-2013, 11:55 AM
RE: Today's Antique Show Finds... - by Jayce - 10-22-2013, 02:58 PM
RE: Today's Antique Show Finds... - by Jamie - 10-22-2013, 03:15 PM
RE: Today's Antique Show Finds... - by TA Forbes - 10-23-2013, 12:55 PM
There are currently 5011 online users. [Complete List]
» 3 Member(s) | 5008 Guest(s)
