Restoring a 39-7
Nice set! You've got the delux model with the brass escutcheon around the dial. Many years ago I had the chairside version of that set. Wish I hadn't sold it! Good player and very sensitive too.
Restoring a 39-7 - by rworne - 08-15-2013, 10:34 AM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:18 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 03:27 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:34 PM
RE: Restoring a 39-7 - by BrendaAnnD - 08-30-2013, 05:13 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 05:22 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:05 PM
RE: Restoring a 39-7 - by morzh - 08-30-2013, 06:17 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 06:29 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:52 PM
RE: Restoring a 39-7 - by Arran - 08-30-2013, 10:42 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 12:32 AM
RE: Restoring a 39-7 - by Jamie - 08-31-2013, 02:36 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 03:25 PM
RE: Restoring a 39-7 - by hunter2115 - 09-05-2013, 09:31 PM
RE: Restoring a 39-7 - by morzh - 09-05-2013, 09:38 PM
RE: Restoring a 39-7 - by rworne - 09-05-2013, 11:12 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 09:49 AM
RE: Restoring a 39-7 - by Mondial - 10-22-2013, 09:54 AM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 10:14 AM
RE: Restoring a 39-7 - by Radioroslyn - 10-22-2013, 05:53 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 08:28 PM
