It's ALIVE!
Hello Audin, Congrats on getting your radio working! You didnt mention in your previous post if you had a longwire antenna attached after initial powerup of the chassis? These old sets need about a 20'-25' pc of wire attached to the ant terminal for good reception in most cases. Enjoy your Philco! Icon_wink
It's ALIVE! - by audin - 04-09-2008, 12:42 PM
[No subject] - by Texasrocker - 04-09-2008, 06:16 PM
[No subject] - by audin - 04-09-2008, 06:35 PM
[No subject] - by Ron Ramirez - 04-09-2008, 08:06 PM
[No subject] - by Steve Davis - 04-09-2008, 09:03 PM
[No subject] - by audin - 04-09-2008, 09:17 PM
[No subject] - by BDM - 05-29-2008, 11:19 PM
