It's ALIVE!
Initially I didn't have an antenna. On the third or fourth attempt I hooked up the old power cord wire as a quick one. I live in Seattle, so there are a lot of strong signals around. I have not hooked up the ground wire. I'm wondering if I should just add a three prong cord for that part...
It's ALIVE! - by audin - 04-09-2008, 12:42 PM
[No subject] - by Texasrocker - 04-09-2008, 06:16 PM
[No subject] - by audin - 04-09-2008, 06:35 PM
[No subject] - by Ron Ramirez - 04-09-2008, 08:06 PM
[No subject] - by Steve Davis - 04-09-2008, 09:03 PM
[No subject] - by audin - 04-09-2008, 09:17 PM
[No subject] - by BDM - 05-29-2008, 11:19 PM
There are currently 10183 online users. [Complete List]
» 3 Member(s) | 10180 Guest(s)
