1941 Philco push button on/off switches
That sounds similar to what I did with the switch I installed (this was in the 41-250). The problem I had with it was not enough spring action to return the button back to normal position, plus when it does come back, it's inconsistent - it was a while ago, and my "CRS" condition prevents me from recalling the details. Icon_smile
At some point, I'll try the procedure and switch part you described. At the very least, I think I need to secure the switch a little better.
Thanks for the tip.
Bill
Sent from my Pentium II on the AT&T Dial Network
[No subject] - by Ron Ramirez - 11-22-2005, 12:50 AM
[No subject] - by Bill Hutchinson - 11-22-2005, 08:05 PM
Success! - by Raleigh - 06-13-2007, 06:23 PM
[No subject] - by rickd - 06-16-2008, 03:22 PM
[No subject] - by Chuck Schwark - 06-16-2008, 04:08 PM
[No subject] - by rickd - 06-16-2008, 05:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
