It's ALIVE!
Now THAT is a neat picture! Icon_smile
When your radio began working (but with squeals), did you have the large tube shield in place that goes over the tubes lined up along the back of the chassis? If not...then, not having the tube shield in place will cause squealing.
It's ALIVE! - by audin - 04-09-2008, 12:42 PM
[No subject] - by Texasrocker - 04-09-2008, 06:16 PM
[No subject] - by audin - 04-09-2008, 06:35 PM
[No subject] - by Ron Ramirez - 04-09-2008, 08:06 PM
[No subject] - by Steve Davis - 04-09-2008, 09:03 PM
[No subject] - by audin - 04-09-2008, 09:17 PM
[No subject] - by BDM - 05-29-2008, 11:19 PM
