Need help restoring my 40-180 - SUCCESS
Threads: 8
City: Central PA
I'm working on rewiring item #37 on the parts list, 2nd IF Transformer Assy. I've removed it from the chassis and pulled the core out. Surprise! There is a resistor inside that is not on the parts list. It measures 50k on my meter. Can someone please confirm the value of this resistor for me? It appears to have a gold (yellow), pink, and orange stripe on it.
RE: Need help restoring my 40-180 - by EricS - 10-23-2013, 09:28 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 3086 online users. [Complete List] » 1 Member(s) | 3085 Guest(s)
